CitronPresse
A little positive today: the VCs were easily removed, no stuck bolt! I was just unlucky the last time I guess!
I have 2 new questions:
1) I have to find new gaskets obviously, I was told that it's better to buy reinforced fiber gaskets rather than the "old school" cork gaskets...first, is it right or the cork ones are just as good and "leakproof"?
All those I find in reinforced fiber are for the HP engine (High Performance), the only difference I see is the absence of the little "tabs" that come out of the valve cover
Old-school cork gaskets for regular engine:
"New tech" fiber gaskets for HP engine:
I can't find fiber gaskets for the regular engine (with the "tabs"), I imagine that if I put gaskets without "tabs" it will leak?
I'm stuck with cork gaskets, unless someone has a good place to find fiber with "tabs"?
I tell myself that it must exist because the old ones on my car have the "tabs" and are not made of cork, they seem like a kind of blue silicone.
2) After removing the old gasket from the VC and after having scraped the cylinder head and the VC to clean them, if I put the latter "dry" on the cylinder head I notice that it is not perfectly straight, it is slightly "twisted" and doesn't rest evenly on the cylinder head, I don't know if I can clearly explain my point I'm not very good in English sorry
I suspect this is not normal, should I buy new valvecovers or the gasket will do its job anyway?
Thanks in advance!!
Thanks in advance!!
