- Joined
- Nov 14, 2010
- Messages
- 28,325
- Reaction score
- 27,855
What?
What?
Kenworth or Peterbuilt, what's the difference?So it all comes down to a part# that you cannot reference, a stamp that I could add to the pad myself and .025" of cam lift. Things like taller pistons, intake and exhaust manifolds, carburetor calibrations, distributor curve, are all just unimportant parts, gotta have that stamp and .025" cam lift.
You guys sure can split hairs, more power to you, carry on. Thanks
What?after awhile it just comes down to...
the pure minutiaWhat?
Go for it. I would fuselage coup cars are seemingly mighty rare outside car shows unfortunately.A friend found one and has passed the owners info along to me. I may pursue it.View attachment 303434 View attachment 303435 View attachment 303436 View attachment 303437 View attachment 303438 View attachment 303439
For what it's worth, I was only asking as I was curious as to how odd a 383-4 PH23 would be...
Not much, same parent company. The fleet versions if the nameplate is blocked off you have no idea.Kenworth or Peterbuilt, what's the difference
They are the same body shells per line so really no difference other than the sales broucher. Sure you can argue that they are different models, but they are the same.Barracuda or Cuda
Coronet or Super Bee
Satellite or Road Runner
What's the difference
If all 68-70 383-4 are HP then asking how many 383-4 HPs were built is redundant. Why would you need to include the HP designation unless you need to distinguish an HP assembly from a standard performance assembly?
If Mopar considered all 68-70 383-4 to be HP then the question should be why they even bothered to stamp some blocks HP but not all.
If all 68-70 383-4 were HP, then the question should be why does there seem to be a higher percentage of these assemblies stamped with HP in B and E bodies and not C bodies?
Sorry to see the O P is still frustrated, I'm enjoying this thread and I've picked up some great info. Seems like the marketing people and the engineers had different ideas on what makes an HP motor.
The machined pad next to the distributor.That's the crux of it right there.
Where would the HP be stamped on a 383? Pan rail?
Kevin
