The car and engine:
-66 Polara, 383 0.030 (389 cu.i.) flat forged pistons @0.019 down the hole, Edelbrock RPM intake, E-Body HP manifold, 2.5 double exhaust, 650 AVS2 carb, cold air intake air cleaner, 3.23 Auburn rear end, 915 heads, stock rebuild -66 727 with a valve body from -71 (with part throttle kickdown), full throttle shift @ about 4.700 rpm..
As the C-Body is a heavy car I choose the very mild Lunati 256/262 cam (Voodoo Hydraulic Flat Tappet - Chrysler 361-440 256/262) and I'm very pleased with the performance the last 3 years.
I've got the power where I want it.
BUT I have the stock TC and it have a stall speed @ about 1500rpm (measure from when the tires start spinning during breaking) and even if the cam makes a good torque down low, the stall speed is to low to get a decent start from standing still. (The RPM intake kills a bit of low end but I have the "regular" Performance intake before and will never go back, the RPM intake is my absolute favorite).
I want at least another 500rpm stall speed but not too high, I still want to use the car as a daily driver.
I'm from Sweden and it's difficult to get a custom buid so I'm looking for one of the shelf and these two are avalible at my local shop:
Hughes Performance Street Rod Torque Converters 24-20
Or would I not feel any difference from stock TC?
Or should I go with this? Hughes Performance Street Master Torque Converters 24-25
