OK folks, I rebuilt the engine a few months ago. I have around 2500 miles on it, with no problems. I ended up with about 8.8:1 compression, and went with the Performer intake. It has 2.25 dual exhaust with H pipe, and a higher stall converter. I re-curved the distributor (single points) to 11 degrees at the cam, or 22 at the crank. I have tuned it about as far as it will go. It runs with no ping at 28 all-in on 87 octane, where I am getting really close to 95mph in the 1/4 mile. It takes off very well with no hesitation anywhere. I can turn it up to 32 degrees, and it REALLY takes off there, but it pings on low grade gas. My new challenge is that it will not run over 4000 rpm. I just replaced the distributor tonight (reman single point), as I was having trouble keeping a steady time with the old one. It cleared up the variance in timing, with no change to max rpm. I want to slowly but surely upgrade so I can run up to 5200-5500 if I want to. Should I be looking at a performance coil and bigger wires, with or without a Pertronix conversion, or do you think I am starving for fuel, and need to move up into the 650cfm-700cfm range? It runs smoothly all the way up, by the way. No hesitation, no stumbling, and I am well over 100 mph on the speedometer.
