It's a tough call,,,you have just contacted the dealer and it's on record you didn't use a factory approved filter,,and you did it yourself,,41 psi sounds ok but if you haven't followed the factory guidlines,,,,if you slide through this one DON'T EVER HAVE ANYONE CHANGE YOUR OIL UNLESS IT'S A CERTIFIED SHOP THAT KEEPS RECORDS A DEALER WILL ACCEPT,,,,,,, otherwise you will lose in the fine print,,,
Total BS. And for what it's worth, no name or VIN number was given when I talked to the service guy. And I will continue to change my own oil. I am not a "the sky is falling" kind of guy.
