- Joined
- Nov 14, 2010
- Messages
- 28,565
- Reaction score
- 28,449
Rear springs/shocks, get the Auto Pilot and Sentinal lighting working and continue driving it everyday that the weather permits.
It was also a falls view room!:grin:
1,220 miles in 5 days and I only had to spend the last 16 miles on a flatbed...
fuel issues that I'm still trying to figure out, much improved after a new pump and a reroute of one section of fuel line that was close to the exhaust but I think I'm still vaporizing fuel out of the carb. Here's a kool pic from the ninth floor of the hotel in Niagara Falls.
hey matt. ditto..bummer on the flatbed thing but its seems the CC did well overall.
I gotta rap with ya a bit later about my fuel issue on my CC...its kinda p*ssin me off and I don't have the mechanical expertise to challenge my guys on why.
See you smartly stayed on the Canadian side of Niagara Falls...American side is struggling but trying, but still not as cool as what's going on on the Canadian side.![]()
Tell me more. What's going on over there? Wife has been wanting to go to NY and maybe visit the falls
New pump(it did need one), the filter after the pump is new before this trip, I added one just before the pump, abandoned an original steel line that runs through the frame rail and comes out pretty close to the exhaust down pipe and replaced it with rubber and rerouted away from exhaust. Blew out the last remaining steel line, raised the float level in the brand new 1406 and got rid of the brass weight on top of the check ball under the squirters. The lines from the pump to carb are all new. The gas tank is original and I've not had it down and that is on the agenda. I did notice some very fine particulate in the fuel bowls when I had the carb apart and that is what I suspect is causing my remaining issue which is now very minor. The car is running fantastic almost all the time but the carb does get hot in spite of the phenolic spacer. I also added a clutch fan and per the gage, the car does not run hot.Have you gone for all the obvious stuff? Plugged fuel filter? Blown the fuel line out from the tank forward? Does your car run at all? Just guessing, but a trip of that length will do a good job of jostling all the fuel around in the tank and any of the fine silt that accumulates could have gotten stirred up into suspension and has ended up depositing itself in the carb. You'd need a fuel filter that could handle 1 micron or less to get that stuff and AFAIK, nobody makes one. Most fuel filters are only good for about 10microns.
Can't recall: Did you put a "new" tank or a `new to you' tank in the car? "New" tanks will have a coating in them to keep the ethanol and water from eating the inside of the fuel tank and rusting it from the inside out. Otherwise, you might be looking at a trip to a rad shop to boil the tank out and then getting it coated to seal the steel.
You have my number and can call me anytime my friend.hey matt. ditto..bummer on the flatbed thing but its seems the CC did well overall.
if I continue to have an issue I will add a small pusher pump back at the tank.
That's exactly what I'm going to do the rest of the season, Dave.
These guys will be at the Carlisle Fall Show....the price is about $100 less at the show. You could ask Mark to purchase it for and have them ship straight to your door.
http://www.gastanks.com/1967-73-Fur...-Newport-Polara-w_o-Vents/productinfo/CR-20A/
