I sell Kevlar hot sleeves on my Snapon truck. Cover your hand with a thumb-Hole and up to your elbow. Made by Mechanix Wear.
Roughly $25-30 bucks.
i was actually thinking oven mitts.
Intake gasket drawing air on engine side/lifter valley. Causing oil fouling, and cylinder running lean. Check torque on intake bolts, you did use thread sealant on intake bolts right?
As to sealer on the intake manifold bolts
The bolt holes go all the way through toward push rod passage/area. Can pull oil up through the threads and small surface area toward intake port.Are you suggesting oil would travel up the bolt and past the gasket to intake runner
My standard is the paint both sides of intake pan with High-tak/aviation gasket cement, + thread sealer on bolt threads.
Permatex, thread sealer is fine.checking now cold. What thread sealer do you use
< virtual hug >Very disappointing and frustrating.
