Cags70PolaraConvert
- Joined
- Feb 24, 2012
- Messages
- 383
- Reaction score
- 231
Thanks. To check for spark the motor needs to be turning over, doesn't it?
Small wire is red on Mathilda. The lugs on her are close enough to bump w a large flat-blade screwdriver.you can do the same with the starter relay on your car. bridge from the large + lug to the small lug with the starter wire ( can't remember the wire color off the top of my head)
YIKESWhile the engine is running, how many here have grabbed the coil wire with one hand while leaning on the radiator support with the other hand?
I did one that was pretty bad.While the engine is running, how many here have grabbed the coil wire with one hand while leaning on the radiator support with the other hand?
ha,ha, i still use my timing light with the coiled wire that goes between the plug and wire.I did one that was pretty bad.
Remember the old style timing lights before the inductive style became popular? You would pull #1 plug wire on the cap and put a metal piece in the line and plug it back in. Then you would clip the trigger wire for the light to it.
I was using my old light, my spare, at the track. I had just installed a new MSD7 and I was playing around with timing settings.
My right wrist brushed the clip on #1 and my left wrist was against the hood pin. The shock was the worst I've ever had... before or since. My muscles contracted hard on both arms and across my chest... and I felt it in my heart. I seem to remember that with the coil we were using, the secondary voltage was around 45KV.
It stunned me pretty hard... and I was sore after that, especially my chest. I was probably about 24 years old at the time. Looking back at it, I don't know if I could take that kind of shock across my chest today.
i've done the same thing. your arm jumps around like a frog on a hot plate for a minute or two.
That is what I thought also, but once I put a heat shield on, it went away.i think it was my charging system heating up the coil. I haven't had any problem since rewiring the alternator and fixing what my mechanic did. He removed my voltage regulator when I upgraded the ignition with an ecu. I've decided to try and do as much as possible myself with the help of the board since that happened.
