Webb May 1. You can dig in/nerd out at the link.
Webb Finds Water Vapor, But From a Rocky Planet or Its Star?
The upshot.
Webb looking at a rocky (Earth is a rocky planet) planet 30% bigger than Earth, 26 LY from here, orbiting a "red dwarf" (thought to be the most plentiful type of star in the Universe, and the smallest and coolest type).
The Webb spectra of the solar system reveals water vapor, one of the chemical signatures Webb is looking for. We find water in the area, it could be an atmosphere around the rocky planet.
That in turn means there could be some kind of water-based "life" on that planet ("GJ 486 b").
OR, given the star is a red dwarf, the water vapor could be coming FROM the star, possibly in a "sunspot" or some other "cooler" (temp-wise) area of the star and NOT from the planet.
"This graphic shows the transmission spectrum obtained by Webb observations of rocky exoplanet GJ 486 b. The science team’s analysis shows hints of water vapor; however, computer models show that the signal could be from a water-rich planetary atmosphere (indicated by the blue line) or from starspots from the red dwarf host star (indicated by the yellow line). The two models diverge noticeably at shorter infrared wavelengths, indicating that additional observations with other Webb instruments will be needed to constrain the source of the water signal."
Last, the planet is NOT in the "goldilocks zone" of the star, the distance FROM the star (like Earth is in our sun's goldilocks zone, where water can exist on our surface as a liquid). Its TOO CLOSE to its sun. Temp is 800 degrees F on that planet .. no likely way for water to exist as a liquid on THAT surface.
Plus, it is UN-likely the planet has an atmosphere given is closeness to its sun... x-ray and UV-ray's FROM even a dwarf star would have blown away any atmosphere on the planet LONG ago.
Artist's conception of the system.
What's next. The space kids have found the water. That's great. Another confirmation that Universe is FULL of water, EVEN where the solar system configuration means it UN-likely to have any kinda life WE recognize.
Now, they gotta keep look at more/different, short wavelength spectra to see IF they can determine the source of the water .. the sun, the planet, or just floating in space.
Stlll, no matter what of IF they figure out where the water is, Webb is doing great work - exceeding expectations.
The upshot.
