What are these Magnum wheels worth?
'69FuryIIIConvertible
Fixer of junk
Newcastle, Ontario, Canada
What would 4 of these be worth? Trying to figure out what I'll offer the scrapyard, Nigel at National Moparts called me this afternoon and told me he had 4 center caps in good shape for them.
Nick
Stock Aluminum 15 inch road wheels for 79 Chryslers...most associated with the Cordoba "300 edition"
not much since the centers will cost more than the whhels are worth.
If you take the ring off of the wheel this is what it is. My dad has a 79 300 and he has the same wheels with the same trim ring going around them and the centers.
Actually, this is what is under the cast. Just like the road wheels except no chrome. These are what is under the wheel covers on my Monaco. I removed all the cracked and broken pieces of the turbine to get a set of 7" wheels.
Nope...these are the Aluminum road wheel...yes underneath the bolt on fins are slots LIKE the road wheel you show, however the centre cap won't work without some massaging and the area that is painted on the steel road wheel is "reversed"..ie it sticks out, not tapering to the centre cap. Also trim rings won't fit. They are NOT the same.
