I wanted to install seat belts in the rear seat of my 300L. Gotta have them for the grandkids.
I pulled the seat bottom and discovered the foam had hardened and turned to dust... So that meant a bit more work.
Rear floor covered in foam dust.
A tag shows this is a Legendary cover made in 1997!
Foam was so dry it crumbled.
And interesting that it had a Forward Look logo.
Burlap was bad too.
New burlap with the metal stays inserted. That was a PITA.
I forgot to take a pic of the new foam. I used some 1" 44lb high density foam I got from Amazon.
I like to do this when it's warm out, but 55 degrees was the best it's going to get for a while. With the cold and a used cover, it was really tough to get the bottom of the cover down far enough to clip it with the hog rings. I can't remember where I saw this trick, but it works nice... You use zip-ties to pull everything down and stretch the cover. Push and tighten until the cover is in place and you can use the hog rings to secure it.
Finished... Came out OK.. I think if the cover was new, and stretched easier, I could have done a little better, but it's good. Still have to do the seat belts!
Very nice work, John!
