xxcarguy
Had a sunny day so we got it out and drove to Rotary.
Buffed like crazy..... It's working though.
wouldn't be a short. would be a weak internal connection. have seen it happen, but very rare. have seen weak cable connections in moulded battery clamps also. where checking for voltage drops with a test light comes in handy.internal battery short
I started the wagon and moved it to the middle of the garage to check a few things in preparation for taking it to breakfast tomorrow. Did my checks and went to start it - totally dead! No clicks, headlights don't work, nothing. I went to the battery cables first and found a loose ground cable that wouldn't tighten anymore, bought a new cable assuming that was it - wrong! Checked battery voltage which was 12.7, charging it now to see if that does anything. The battery is less than a year old, I'll take it to Autozone for testing tomorrow - the few other times this happened on other cars it turned out to be an internal battery short. I'm just thanking my lucky stars this happened in my garage and not on the road. Anyone have the same problem?
My 2014 pickup battery did that last fall. Showed voltage but no power. Would put a charger on it and it would show charged. I could jump it and it would run. If I had it off for a few minutes it would still start. After a couple of hours wouldn’t crank again. Put a booster pack on it or jump it. If it starts its probably not your bulkhead or starter connection and is your battery. If it still doesn’t have start move down the line testing power through your fuesable link and bulk head.I started the wagon and moved it to the middle of the garage to check a few things in preparation for taking it to breakfast tomorrow. Did my checks and went to start it - totally dead! No clicks, headlights don't work, nothing. I went to the battery cables first and found a loose ground cable that wouldn't tighten anymore, bought a new cable assuming that was it - wrong! Checked battery voltage which was 12.7, charging it now to see if that does anything. The battery is less than a year old, I'll take it to Autozone for testing tomorrow - the few other times this happened on other cars it turned out to be an internal battery short. I'm just thanking my lucky stars this happened in my garage and not on the road. Anyone have the same problem?
I have seen similar issues occur in estop switches, switches, contactors, etc. Not enough conductor to carry current but voltage (potential) will read good on a meter.Had the same type of symptoms a few years back on a riding mower, showed plenty of voltage. Turned out it was a bad battery.
Thanks for the replies on my no power problem. Let me mention again that this is not just a starting issue, the car is completely dead - no start, no headlights, no power windows, nothing. Here's where I'm at now:
Using the FSM wiring diagram I identified the two fusible links coming off the solenoid switch, I wiggled and inspected them and there is no visible damage. If they blow, how does that work? Can you actually tell by looking at them? I had to quit working on it today , sure need to move this garage ornament...
- I took the charged battery to Autozone, it checked out fine - 12.87 volts.
- Battery back in, all terminals cleaned and tight. Pulled the headlight switch and wiggled everything, solenoid switch wires, bulkhead connector, etc. no change.
- Removed all wires from solenoid switch, cleaned and tightened all connections. With battery connected I get 12.87 volts at the large terminal - no change.
- I tried jumping the large and small terminals at the switch, nothing.
