1969 Imperial progress thread
Great work on the dash lens and the carb parts .. I'd still get a kit and put it back together.
As long as those cracks don't allow a vacuum leak no worries
If you think it's still worth the rebuild, I would try it. I have not the experiance to decide that...
Damn. I thought this is be the end of the holley... A new base plate cots $105. I should have checked that before cleaning and polishing all these parts for 3 days...
Could be that a little JB weld might help. And as many of those carbs were made someone may have a donor base plate avaliable. I try to keep the orignal parts off my car. Otherwise i'd just give you mine.
With the kit already bought I'd also give it a try, shouldn't be a problem to get another base plate if necessary.
J-B weld sounds interesting. I'll try to get a replacement base plate here in germany or try J-B weld. This $25 base plate looks good, but $50 shipping is crazy.
Would be great to find one over here.
As I wrote, I'm back from Hospital and will try to do some work. I'm not allowed to use my leg, but I have a few things at home that I can do.
I can reassamble the carburetor now, after I had to order some gaskets and o-rings that were not included in the rebuild kit.
Good to have you back! Similar thing happened to me in June 2012 with my shoulder. I missed a whole summer of work on the car.
Carburetor rebuild
I finished work on the Carburetor today. I soaked, cleaned, sanded, polished, rebuild and reassambled it with new gaskets, jets, valves, diaphragms, springs etc. etc.
Looks really good! I hope it will work as good as it looks!
And now a lot of before and after pictures:
I was a little worried about you. . . Real glad to see you are back.
Vodka ! That is an amazing transformation. You do excellent work. Looks like the vinegar did its job.
Looks like new buddy! Nice work!!!
:D Thanks!
According to the weight, probably 200 bucks or more ;)
I payed $25 for a small book from NY to Germany...
