A Dodge Charger fb group, here's a creenshot of it. I've asked for a contact number for you, see if he replies. What's the red x for bud?Where is the ‘69 B9 Imperial posted for sale? I’ve been looking for a 4 door in that color for a long time.
Thanks! Red x was by mistake, sorry.@Imperialist seller's number is +17166802300.
Great idea and it’s unfortunate that the threads were incorrectly cut. You might have to get replacement ends. Correction of the end to get the threads square with the face of the end may be impossible…Finally, my modified Strud Rods are "done". Unfortunately, the mashinist, who modified the original strud rods, screwed up the new threads... They were cut crooked, resulting in very shallow threads towards the ends. One even doesn't have any threads on one side. And that's the part where the locking nuts are sitting, so not an option to use them as they are now.
I hope he comes up with a solution to solve that problem.
But besides that, I'm very pleased with the basic idea and the general result of my initial idea.
I bought an adjustable Strud Rod Kit from QA1 for B-Bodies (#52312)
The original Imperial Strud Rods with their big, mushy bushings are pretty inaccurate and not adjustable to correctly set up the caster.
Since Imperials have a unique way to attach the Strud Rods to the Lower Control Arm, I had to use these "hockey stick ends" of the original Strud Rods and modify them to attach them to the QA1 parts.
When cutting them, I left enough lenght to mount them in the lathe chuck.
They were turned down to .625" on the lathe to accept the new 5/8-18 UNF left hand threads.
Next, they were trimmed to the final lenght. I planned for 70mm long threads to have enough adjustability later.
Fresh off the lathe, before the "crooked" threads were cut.
The QA1 center tube had to be cut down 70mm, 35mm on each side, to achieve the total lenght of the original Strud Rods later.
Because of that, new flat spots for a wrench had to be cut and the internal threads had to be extended inside the tube.
And ready, almost, are the adjustable Imperial Strud Rods!
As soon as the threads are fixed, they will get zinc plated and painted and then installed.
Correcting it is probably impossible, yes.Great idea and it’s unfortunate that the threads were incorrectly cut. You might have to get replacement ends. Correction of the end to get the threads square with the face of the end may be impossible…
That's how QA1 has built it. They used Steel bolts initially as well. They applied a generous amount of anti-seize tho.Excellent modification and beautifully recorded. Thank you! - The only thing I would be worried about is possible corrosion btw AL-tube and Fe-threads. Aluminum and steel do not like each other if there is any moisture at all. And in suspension components, if the vehicle is not a trailer queen only, there is always dampness around. (The added weight of steel tubes in place of aluminum ones, in this case, would be insignificant.)
That was the first thing I thought as well, but I measured the shaft and it's, within an acceptable tolerance, all the same from left or right.It isn't the thread that's shallow. The OD of the threads is tapered.
What has happened is it was sticking out of the chuck too far and the first cut was too deep. Looking at the chatter marks, I also wonder if the cutting tool wasn't on center, possibly set too low. The "hockey stick" portion sticking out can also cause some balance issues that compound the problem, especially when it protrudes that far out of the chuck.
Cutting a part like that requires everything be right in the setup and some patience with taking light cuts, making measurements to check for taper. Back in my Toolmaker days, we would have said "you gotta sneak up on it". Hmm.. I'm now remembering the smell of the shop.... black cutting oil, beer farts and unfiltered Lucky Strikes. Smells like victory.
All that said, I think they are usable as is. You have the lock nut on the other end that will keep it from turning, so that's not a big worry. If you look at how they mount in a B body, you can see why there's a lock nut. With the "hockey stick" that end can't turn. The portion of the thread in the tube is good. I'd still use the locknut as it would take any looseness out of the threaded joint.
Well, it's done! My 1½ Years long search got to an end. Thanks to all you guys supporting me
A special thanks goes to Dano for all his kindness and patience. He's a really nice guy!
Another big thanks goes to Matt (detmatt) for all his help during my search!
It will take a few weeks until I have the car here but I can start with sharing all pictures I have.
I will do a total restauration from top to bottom and try to do as much as possible by myself. This will take a few years. Or even a few more... but I'm not in a hurry.
I'm sure I will have a lot of questions during this process!
Cheers, Julian
View attachment 22688View attachment 22689View attachment 22690View attachment 22691View attachment 22692View attachment 22693View attachment 22694View attachment 22695View attachment 22696View attachment 22697
Thanks Stan, happy to hear that! I will get back to my project next year again more frequently, so stay tuned!I want to thank you for the enjoyment you have brought me for 11 years!!!
Nearly a month since you posted. You must be busy!Thanks Stan, happy to hear that! I will get back to my project next year again more frequently, so stay tuned!
And likewise, Mr. GrumpyOldMan
I'm waiting for my dad to finish the technical work on his project, since he occupied my shop for it for the last year.Nearly a month since you posted. You must be busy!
