70bigblockdodge
Score, and excellent advise, from Big John.
I hear you on all of that...and its probably sound advice...only question i have then is how will I know when i need to do the seats if I dont take them off? leak down test? measurements? I read so many things about the valves sinking into the heads and destroying them. I just want to make it runs nice with maybe a bit more power. It seems sluggish right now compared to my past 383 in my coronet...but then again...smaller car and different gear ratio too...but it only had a 2bbl.Well... If you have the heads apart, it's a great idea to install hardened seats, but in reality, they aren't as necessary as you might think. The idea is that the unleaded gas will shorten the life of the valve seat. That's true to some extent, but you won't see the effects for tens of thousands of miles. Even then, the Mopar heads aren't as soft as, let's say a SBC head. Chances are it will never cause you a problem.
Taking the head off just to replace the valve seats isn't worth the effort or money.
Your compression is even so, most likely not a issue..only question i have then is how will I know when i need to do the seats if I dont take them off? leak down test? measurements
You will have a noticeable problem way before this happenes.I read so many things about the valves sinking into the heads and destroying them
ok....will get into the more timing stuff later...going to replace the timing chain because even if it wasnt abused, it still has 105k on it. I was also getting floating vacuum readings when doing the timing before...a sign of a worn chain i believe. may still go to electronic ignition just to eliminate distributor wear from my current equation.Your compression is even so, most likely not a issue.
At this point you have low cylinder pressure due to compression ratio and cam timing. A new timing chain and some more initial timing will wake it up and give some throttle response.
I'm just going to throw this out there...
The car is running. Change the timing gear set to give you some peace of mind. Then just go out and drive it. Have some fun, work on a couple other things that aren't going to put the car into pieces. The car will run better with good plugs and getting it tuned right.
Too many times I see cars taken apart with good intentions and next thing you know, it's a massive, expensive project that drags on and the fun goes away.
Ok...so I've decided not to rebuild the motor right now. I do need to change the timing chain and remove the oil pan for repair. I've decided to pull the engine completely in order to be able to get the oil pan out, pop the freeze plugs and flush the block, clean and decrease it for paint.
What other things should I look at addressing while the block is out? I'm not looking to break the heads loose right now....unless there is a benefit to raving the head gaskets now while it is out.
I would like to look into rebuilding my 67 newport 383 next year but would like suggestions on what to have done. The car has just over 100k. Stock 2bbl motor with 4bbl added. 727 w/ 2:76 gears. I would like to increase the cam a little...thinking the voodoo 262/268 cam. This would be for a fun weekend driver leaning towards highway cruising for long drives but still with some fun torque.
What work should I have done to the drive line to add a bit more fun but still run on pump gas and get reasonable mileage? Currently the engine has no knocks or major issues...
Thank you for not using that texting gibberish, us old farts can actually read what you said without getting a headache.this is what I did to my 440 I had the block checked for trueness (not out of round)then I had them break the glaze I had the heads cut to get into fresh steel . then I used clvite bearings a double row timing set (I put in a mopar performance resteration camshaft ) I used hastings molly steel rings & I put a new oil pump in herr she runs great! thats what I did the block was still in spec so I dint bore it I just rebuilt it to stock now when I changed the cam I had to change the springs cause the stock springs didnt match the cam (450/458/60* over lap & a 115* centerline
Now you jinks him.The head gaskets really don’t need to be replaced, they don’t fail like 1980’s aluminum head front wheel drive cars
Good thing I broke you guys in on bad grammar. Now your ready for anything, all you have to do is ask.this is what I did to my 440 I had the block checked for trueness (not out of round)then I had them break the glaze I had the heads cut to get into fresh steel . then I used clvite bearings a double row timing set (I put in a mopar performance resteration camshaft ) I used hastings molly steel rings & I put a new oil pump in herr she runs great! thats what I did the block was still in spec so I dint bore it I just rebuilt it to stock now when I changed the cam I had to change the springs cause the stock springs didnt match the cam (450/458/60* over lap & a 115* centerline
