Hi all, It has been about a month or a little bit more since my last update. As of right now and I am trying not to jinx it here, the engine looks like it can be saved! In my last post I messed up and got my information a bit wrong, I originally said it was the 3rd and 7th pistons that were scuffed, IT IS ACTUALLY the 5TH and 7th pistons. Anyway here is the latest....
We Found The Problem! It is as we originally thought, the problem is in-fact the cylinders and NOT the pistons. Another friend of ours named Rich looked at the pistons and he said that the scuffs on the 5th and 7th would not make the car run like it is. So he gave us a measuring tool to borrow to measure the inside of the cylinders.
Yesterday Sunday Feb 23rd- The cylinders were measured, then the pistons were measured for comparison. The cylinder measures at 2,000 difference, and the cylinder measures smaller than the piston so it's a bit tight. It is supposed to measure within 4-5,000
So What Is Next?- Take the crank out and hone the cylinders alittle bit.
Here are some pictures of the engine out of the carView attachment 355747 View attachment 355748 View attachment 355749 View attachment 355750 View attachment 355751
You can continue to mess around with this engine the way you have, but if I was you, I would take the block, crank and pistons to a competent machinist and ask him to figure it all out and fix it.
