polara71
Couldnt tell you. My thought is based on what Ive heard over the last 35 years. Would have been nice
I swear the 70 hurst parts car I had was equipped with a Bendix unit on it just like this one??
The air cleaner hits the compressor.That was supposed to be something with the brake booster hitting the valve cover but if the enthusiast can make it happen I am sure Ma could have
No factory AC on a v code correct? If so then I'm confused as to why there ARE V code C bodies and no Hemis...
My SFGT had a 69 bbl setup that had been added in the early 70's. The A12 air cleaner they used had been cut up pretty good to clear the compressor.
Sorry... Mild brain fart.what compressor? I read the question as , if no A/C why not a Hemi installed in a C .... No?
Yea, usually the problem was they had done something wrong because they "read it in a magazine" and they never could figure out how to undo their mistakes. I bought a couple sets of carbs from guys that couldn't make them "work" after they'd screwed with them. They worked fine when I was done.Some good points, the six pack had its own tuning issues from day to day. Lots of people had the 6bbl pulled regardless of the line of car in exchange for a 4bbl.
All Holley carburetors in the early 70s were junk - they wouldn't last but a few years before warping and leaking (bowls, metering blocks, etc). The castings were of poor metals. Even the Holley representative stationed in the carb lab at Chrysler Engineering in Highland Park, MI admitted they weren't worth trying to rebuild them after a couple years. When I restored my 70 Cuda 440-6, I dumped the original carbs that I couldn't get to run right (and I could see the warpage it was so obvious) and purchased the much later reproduction 3- 2-bbl carbs and haven't had a problem with them in over 20 years now. Even with ethanol fuel in these later years. They always start, while my original Carter AVS carbs always seem to need the accelerator pump or needle and seat soaked in carb cleaner to work well again. The 440+6 engine is a beast and runs better than a 426 Hemi I had in a 1969 Road Runner - it was always tempermental and especially during warm up, was a bear to keep running.
Yea, there was the warpage problem too. I tend to forget about that... Of course I was working as a Tool & Die Maker back then and I used to make the surfaces straight as a matter of course. One way or another. LOL.
The Thermoquad had a bad issue with the plastic body warping. The tool shop around the corner from where I worked was grinding them flat for Carter. It seems they couldn't get it right and farmed it out to them. I don't know if they did all of them or just doing test runs. They were very tight lipped about it.
Yes, my point is if AC was the reason for not producing a hemi in a C then why are there 11 V codes out there (no AC on a V code)? Mopar was going for the muscle car effect with the V code GT, Why not go all out?
You're scaring me with all your knowledge that tells me you were an insider back then.Good question,....easy answer. Chrysler Co. did not build ANY V-code/6BBL/SIX-PACK car with Air Conditioning; either E-Body, B-Body, or C-Body. The 6BBl air cleaner assembly made contact with the A/C compressor, and Ma MoPar wasn't going to re-engineer that! No A/C in a 6BBL car, period.
There is one car, dealer installed, but not from any plant. TTBOMK.
Also, on the "Hemi" C-Body question....the 70 Hurst 300 was slated for the 426 Hemi as standard engine, but as a "mid year" release, there just wasn't time to engineer the mounts, exhaust, etc.
Can you imagine well healed "executive" owners of Sport Fury GT's taking their Hemi powered car for a tune up every month because of poor running conditions, especially in the winter months? The 6BBL option makes scene, from a manufacturing/sales platform.
Ask me about Formals..thought that was common knowlage....
I'd like to post progress of the "Holy Grail" of our C-Body hobby.
The only known TX9 Black Velvet on Black 1970 Sport Fury GT 6BBl.
Special ordered new by Rod Kesler on September 23, 1969, at the young age of 24, from Monroe Chrysler Plymouth of Toledo, Ohio. At a total of $4,473.20.
