oh get some inline fuses. make the ALT <> BATT wires. I used 50a fuses on each end / both ends. cbarge or someone used a fusible link. both have reasons.
you CAN put a bigger ALT up to like 65a or so i forget, or the powermaster 110a ALT or such - but then past stock amp levels you need to beef up your charging wires up to 10ga.
and the wires are old AF. its good to run a new line with fuse protection.
NOT a self resetting circuit breaker. it must be a once/fail type of circuit. the fuse breaks or the fuse link melts. Personally id fuse both ends the ALT side and the BATT side.
i undid my ALT once and plumb forgot it has a hot post on it and set it up on the fender... pretty soon the whole side of the car started getting hot...
unhook your BATT + before anything.
try not to die -
- saylor
Gotta remember those were film strips way back when...
There's a couple great sources for those "Master Technician Service Conferences".
The Imperial club has a lot of the literature and some of the video/film strips dating back to 1947. Great factory info there. You can't go wrong with how they do things. Master Technician Service Conference - Chrysler's Training for Mechanics
The other can be sourced through YouTube and will have a lot of other advertising videos too. https://www.youtube.com/user/mymopartv/videos or it can be sourced through their website with a better index system. MyMopar - Mopar Forums & Information - Browse MTSC by Topic
I always like to look at the non-sorted/indexed stuff though. Things catch my eye that I might not be looking for.
Hey Big John,
I am getting in deep with the service tech. write up, GREAT info.!!! I am learning much. Still trying to get the whole system straight in my head but that is a great resource, thanks!
You mentioned a go-around for not using a carbon pile to test under load? I'd be interested to hear how that works. Meanwhile I'm reading up on the charging system and gearing up to do a bunch of testing. I have an analog multi-tester and Mexican electrical circuit analyzer (bulb on an alligator clip) and am thinking about a fire extinguisher to round out the tool kit. But hopefully I can discover an issue or 10 that can be addressed before something goes bad.
I do need an alternator though. Stock or high-output, I need to have something as my old one sounds like the Fred Flintstone lunch siren and has changed it's metal composition- white and chalky. No bueno. Knowing what you know about my situ do you have any recommendations on what to bring down??
Mopar singular? Ha... That's funny... I had a bunch of them and they were often just this side of hitting the crusher. Salt has its way with electrical systems and doing things like shorting a salt corroded starter relay with a quarter while waiting for a day when it was warm enough (and not snowing etc.) to actually change it or plugging in a new (or used) headlight dimmer and not being able to screw it to the floor because there was no floor to screw it to was typical in my youth.Thanks for sharing the story about daily driving under major electrical load back in the day. Sounds like your mopar did it's job and without any modifications.
That's the point I'd like to get to. Lights can dim just don't leave me sweating the morning startup cuz I've only got about 12 seconds of turnover before the battery quits...
I have a feeling we'll be back to the dim lights but am hoping the battery holds sufficient charge throughout.
OK, overwhelmed with information at this point. Links, videos, parts to digest. Killer information and much appreciated. This will take me some time.
My suspicion is that when all is working properly on the Fury charging system, with my situation- a lot of low rpm driving at night, my challenge will be to figure out how to boost the system to have better (more) charge at LOW rpm.
With a stock 318 running properly would anyone suspect that driving with accessories on at low-ish rpm would put a drain on the battery? Could the solution be a high-voltage alternator? If so, I've been hearing about frying wires/my car isn't equipped to accommodate a high-voltage (north of 100 amp) alternator. Would the answer be bigger wires??
I know everyone wants me to test it out first. I PROMISE that I will do that. But, very little feedback regarding my specific issue- I drive at night like a little old lady with accessories on- is it not normal, under those conditions, for the battery to be low the next day? The one bit I have leaned since diving into the "don't want to burn up my car" adventure is that the ammeter shows when the alternator is supplying power vs. the battery (d- side of the scale, on the ammeter). I have a feeling that unless your idle is set super high, anyone who drives like that would be seeing their ammeter needle to the left of center and be putting a drain on the battery. I don't have the luxury of testing it out first. I need to plan ahead.
Any how to get a good charge at low rpm threads come to mind?
A little lesson in electrical terminology... You aren't looking at high "voltage" alternators. Alternators make AC (alternating current, just like your house) and it's rectified through the diodes to DC (direct current).
A high output alternator is capable of putting out more current or "amperage". Because the alternator is putting out more current, the voltage in the battery and system is staying where it should.
One of the things that the guys get kinda right and kinda wrong is that the high output alternators put out that high current all the time. They only put out as much current as needed. So some of the worry about doing the bypass when you add a high output alternator is good, but if your car never really draws that current, well, the wiring will never be taxed (and the higher output never needed either).
But, again, it's a good idea and I'll never tell anyone not to do it. It's a safe option.
I really think you want/need a plan... You want to show up with a trunk full of stuff and just fix it all and solve everything. I can appreciate that approach...
So... Let's shotgun a few things first.
1. Replace all the battery cables. I've seen so many problems here and then I look and I see that the battery terminal is one of those clamp on temporary POS terminals that you pull off the cardboard in Autozone. A woodscrew or two jammed in is always a nice touch... Sorry... off on a rant... Replace the cables. While you are at it, get those little red and green felt washers that go under the help the new ends from corroding. I always use those. The point being that battery cables are cheap, easy to replace and often an overlooked problem.
2. Seriously, what shape is the battery in? How old? Is it stored on a trickle charger now? Can you get a replacement there easily? Consider going to a group 27 battery (larger capacity) rather than the original group 24. It's longer, but it'll fit. BTW, I just had to buy a new battery for my little Ford Ranger the other day. Costco blew everyone out of the water on price.
3. It really sounds like you need to replace the alternator and I think you've committed to that. Thinking about it, maybe the 100 amp nuclear option is the way to go. I know you aren't running A/C etc., but you are taxing the system and I don't think that 100 amp aftermarket piece would be any more money than the 60 amp rebuild. Just don't get a chrome one. I hate chrome alternators.
4. Buy a spare voltage regulator. Your choice, the VR-706 above is a good spare option and if after replacing everything, the problem persists, or you determine the replacement you have already installed isn't an electronic version. If all is well, a spare riding around the trunk in Mexico doesn't sound like a bad idea.
5. Get all the pieces together to do the bypass. Yep, I know... I said check everything first, but I've gotten it through my thick skull that this is a "let's just fix everything" scenario. It's just some wire, a fusible link (yes, a fusible link) and a few terminals. Easy to do with good results.
6. Mount a voltmeter in your car. This will give you all you need to know about the charging system as you drive. Don't want to mount one? Buy one that plugs into the cigar lighter. I use one of those myself... Came in real handy the other day diagnosing the bad battery in my truck.
There ya go...
On a lighter note:I appreciate the support. One thing to keep in mind is that I do not want to bypass my ammeter. Got to keep the goofy ammeter. It's part of my Fury driving experience.
You are right when you say, "You want to show up with a trunk full of stuff and just fix it all and solve everything." I should add that no one's tripping on the price of things. That being said if I need to put in a 300 dollar alt. it is money well spent in my mind. I'll be sourcing the new battery down there- gonna go Optima as we've had issues with regular batteries on the washboard simply breaking with all the vibrato. Even though the Fury floats like a fricking blue bird on a cloud over the washboard I feel like the Optimas can rally back from a low discharge better than other types- not that this will be a problem from regular driving for me after the diagnosis and fixes but there are times that the Fury sits for a while w/out a charger. Not important.
New cables= yes. Felt buddies= yes. I will make sure and have two solid state regulators in hand when crossing the border.
This is like the best advice I've been given as to how to make the charging system perform correctly. And I will follow all the steps- once I've had a chance to learn them but in an effort to plan ahead I keep going back to my original query:
Am I right or am I right when I say that under my driving conditions [low speed at night with stuff on] it is normal for the battery to be discharged, even with the charging system working per spec?? It's not normal driving- I'm idling down a bumpy dirt road with moo-moos popping into the frame like bugs on your windshield. I've got to go muy slow- no chance for the old charging system to charge! Wouldn't anybodies car drain the battery driving like this? I think so.
Saylor mentioned looking at a curve graph on the alternator's performance. Maybe this should be my focus when shopping for a new alternator? I feel like maybe I should post again, "need help charging car at low speeds!"
I agree the whole charging system needs a good going through but afterwards I feel like the next challenge will be to figure out a way to charge under low rpm. Any thoughts, anybody?
As far as chrome goes, I'm thinking of chroming the whole engine bay (they'll do this in Mexico for cheap,believe me) and also I found a lead on a trunk accessory that I plan to have chromed as well (see below).
Just kidding!! That's so hilarious- on the same page, I fricking hate chrome parts on stock older cars!! It's kind of like a bum wearing a Rolex- not that old mopars are bums just the out of place factor. It just aint right. I really appreciate a tidy engine bay with period-appropriate painted parts. Go throwing a chrome master cylinder in the mix and it's like, HUH?
If you have a souped-up motor that does wheelies, go for it! I appreciate that too...
Haa!! good stuff!On a lighter note:
Some police cars had a fast idle or throttle handle on them. Others that are more familiar with the police car options and equipment will probably chime in.I think what I've got is kind of like if I were a cop sitting at a stake out with the engine running, heat blasting and radio on. Well, not a stake out cuz he wouldn't have his lights on but if you take a 1968 Fury 2 with a 318 and idle and blast the heat, turn the lights on and the radio wouldn't the battery discharge? Unclear after your last post due to the part in #6.
Maybe seriously it's as easy as setting the idle fast and riding the brakes?
interesting option. I will look into this. Be nice to have a throttle handle that you could do on the fly.Some police cars had a fast idle or throttle handle on them. Others that are more familiar with the police car options and equipment will probably chime in.
That's correct, but in the real world, stuff does happen.But then again after re-reading your post you say in #6 to fast idle to bring the charge up... that shouldn't happen, right?
