Ripinator
That part of it looks right. It’s the rubber hose in between that looks wrong.
The carburetor feeds from underneath at the center rear. It’s a rubber hose connection. Then the hose goes to a steel line to make a 90 degree turn to the front. From there it goes back to rubber before meeting the steel line coming up between the alternator and the block from the fuel pump.
My other mopars have it all steel.
On my '66 440, there is a break in the line from the fuel pump to the carburetor where an in-line fuel filter is installed. A short piece of rubber line connects the lower steel line from the pump to the filter, and another short piece of rubber line connects the filter to the steel line that goes the rest of the way to the carburetor. Maybe that is the extra setup you found with your car. . .
