Refurbish time
Ross sez its important:
http://www.imperialclub.com/Repair/Exhaust/riser.htm
From Ross:
The exhaust heat riser valve is, like the PCV and leaner choke settings of the late 60's era of early emissions devices an ironically good thing for motor longevity. Ironically, because those of us who bemoaned the 1970's crude technology came to hate emissions devices due to the lack of appropriate technology to keep them serviceable over the long run.
Yet this is not true with the above-mentioned: A properly operating riser makes a significant contribution to motor longevity -- and this is important -- in conjunction with a well-calibrated carburetor whose intake air is ALSO regulated. You'll notice that vehicles with "heat stoves" on the exhaust manifold which lead pre-warmed air to the carb, or a BLEND of air heated and not heated, finally only "cold" air as the motor warms up and under-hood temperatures rise above about 85-115 degrees F have a demonstrably shorter warm-up period than those cars not so equipped. The heat riser passage which leads from one end of the passenger-side exhaust manifold (valve closed) through the underside of the intake manifold and on out the driver's side is, when kept clean and operating properly, making a noticeably significant difference in keeping the fuel/air mixture IN SUSPENSION. Once those fuel droplets "fall out" the differences in mixture cylinder-by-cylinder are aggravated, thus making a fair running car lose efficiency. The valve is on the passenger-side on most American cars (trivia time) because Cylinders 5 & 7 always fire one after the other: too strong an exhaust pulse for a valve, yet it aids in "pulling" the charge thru the intake area. It also (heat riser valve) has the benefit of warming the underhood air a bit faster as all that cast iron is being cooked thus enabling the valve to close faster and the carburetor come out of cold operating parameters. Chrysler was ahead of the game in emissions also in the late 60's as GM's needed the dreaded smog pump (A.I.R.; "Air Injection Reaction") to pass the minimal guidelines of the day.
Yes, the heat on the intake underside reduces what is called charge density, but that is really only significant to full-throttle acceleration, and then it is a gain of perhaps 5%. Our kind of ultra-low rpm driving (off-idle thru about 3500 around town) benefits from the "constancy" of temperature regulation, and the attending leaner carburetor calibration. In short, better BSFC numbers on the dyno, (fuel usage versus work performed; most especially in numerous part-throttle transitions), and a LONGER-LIVED MOTOR!
With all that said, no, probably none of us bother to keep the valve operable, it needs a shot of "Heat Riser Valve Lubricant" on the pins about once a month; 90-days without fail (GM used to market the best version of this). Obviously it is also a significant exhaust restriction and eliminating it (not just pinning it open) probably saves more gasoline than it ever did operating. Yet it is fundamental that to have the longest-lived motor, one must shorten the interval from dead-cold to @ F 180 as much as possible as this is where the really nasty **** (sorry, it's the only correct word) gets in the lube oil, very corrosive acid compounds which it takes at least 10 miles/20 minutes of driving @ 35-40 mph before they BEGIN to burn off.
So disabling the valve has a price, albeit over a period of time. Some of us know this and forget it, yet we're the one's who also know that ol' granddaddy who kept that Imp in ideal condition for us to buy also understood it. If it'll work, free it up and let it do its intended job. A low performance Imperial motor needs whatever Ma Mopar gave it. (At least up through 1970). And pull that intake manifold once in a while to clean out the accumulated carbon buildup in the passage. This can solve more than a few mysterious "lowered gas mileage" woes.
I never remove them and an always advocate for them. That's why I'd like to see you press in bushings.
Posted via Topify on Android
Yeah Stan, but I think I like your first suggestion better (tapping it).
I gotta share this.
Yesterday was the first time in weeks I've had the car out in the sun and even with the leaky manifold it was fantastic driving around. I went from my house and across the bridge into Wilmington DE, back across the bridge and up to Pennsauken and then back to home base. That is probably about a maybe 50 or 60 mi drive total. The 383 feels brand new and really moves out. Along my travels I got about 2 or 3 thumbs up. I stopped to tank up at a wawa and out of the blue this dude walks over and tells me about the old mopar he had back in the day. He saw me pull in and got all nostalgic. He was sorry he got rid of his ride back in the eighties (68' Plymouth Fury 2dr w/383). The high point of the trip came when a dick head in a brand spanking new Jag was purposely riding up on my bumper for miles before finally mashing the pedal to get around me. I wasn't going super fast but he had to plant it to speed up and get around me. Well guess what, the man was sitting right around a blind bend and parked facing traffic. I know better not to go speeding around areas like that, those spots are favorites for cops to sit and nail unsuspecting drivers and he must of had radar off b/c my cobra was dead silent for radar and laser signals. We both passed him by. I managed to see the look of terror on the jag guys face. He couldn't slow that heap down quick enough to not fly by the cop. Guess what. The cop pulls out, weaves through traffic, gets behind the jag and flips on the party lights. I passed by him as he pulls over to the shoulder and blow my horn. It was classic.
I LOVE when that happens!!
The "thumbs up" part I could have done without but I knew you threw that in as a zinger. Lol!!
I gotta share this.
I think that is called Karma. I wish that was on video.
It was classic. Moments like that are far and few in my experience. Me, a jack *** in a jag, a cop, & bend in the road. It all came together precisely at the right time.
The culprit..........all this stuff I've just done only to be stopped by this stupid little ****. Damn boat anchor manifolds.
I would attempt to fix it and fix it correctly, problem is can you even get a new bushing for that?
If was a larger issue or something that could be readily observable than I would most likely go out of my way to make it the way it was when it was built but it is tiny I'll never touch again and it can't be seen. Plus the carb has elec. auto choke...so the mechanism itself is duplicative in function.
