1970FuryConv
PINION YOKE OIL SEAL
SKF 18708
* Flange of oil seal is metal and sticks out beyond the edge of the axle housing. Pin punch and BFH to bend old oil seal’s flange away from the front of the differential carrier. Remove old oil seal with vise grips.
Rear view
New oil seal: 60 grit sandpaper on outer edge of carrier to remove surface rust from oil seal mounting hole. Only needed to use the sandpaper on the outer edge; the inner portion was flat and smooth and rust free, and I didn’t want to touch it. Carefully cleaned out any and all debris so nothing could damage the front pinion bearing. Q-tips in oil passage below front pinion bearing. Light coat of wheel bearing grease on inner portion of seal mounting area and on rubber oil seal itself.
· Old coffee cup and taps with big hammer to install new seal. I figured what the heck, if the cup broke, it had a monogram of a company that I used to work for and don’t have any relationship with now so who gives a damn. Use open end of cup on metal flange of oil seal. Stop tapping when metal flange is flush with front of differential carrier. (also used cup for small paint jobs)
SKF 18708
Rear view
