Happy Easter!Happy Easter all!!!!
Left Air Inlet Yoke Adapter 77 Gran Fury CHRYSLER Roya Monaco NOS Mopar 3868245
WTF is a Left Air Inlet Yoke Adaptor?
Close….. but not exactly. Waiting on one final small part to finish and reveal. It’s stuck in transit. Was supposed to arrive Saturday. Now looks to be sometime next week if ever. Just as I head out of town.This is the closest pic I could find of the yoke adapter:
Based on what you call 'clues' (and I use that term loosely!), I see reference to some sort of air cleaner hose adapter, some shallow blue scoopy-thingies, and pics of the cowl.
I am guessing some sort of 70s-Nascar-style cowl-based fresh air inlet to the air cleaner.
But the car is pretty nice, so whatever is done must be tasteful and discrete.
Mounted at the rear of the air cleaner, with the original snorkel retained as a decoy, and the size/shape of the blue things suggest baffles for in the cowl to keep leaves and mice from getting sucked in.
Am I close?
Sounds like there's another Stan out there somewhere, putting a doesn't-belong modification on a car, and doing it with style.I once saw a Sinatra Imperial with a s
Shaker. Extremely well done enough to equal factory. It looked terrific.
I say there's a lost opportunity here...
Sounds like there's another Stan out there somewhere, putting a doesn't-belong modification on a car, and doing it with style.![]()
He’s my hero!Sounds like there's another Stan out there somewhere, putting a doesn't-belong modification on a car, and doing it with style.![]()
I completely agree. I've had some on hand ever since my '84 Ram that had inoperable wipers. Used it last on the Cicada, my '68 Monaco 500. I love that stuff.RainX is a wonderful product that deserves a Nobel prize for automotive progress... Even without the wipers I can see well enough to feel safe. And above 40mph, the rain just blows off.
Curious to see what the Trans issue is Jav…had mine rebuilt last year and ever since, it won’t engage right away once places in “D” or “R” until warmed up or accelerated on to build up pressure..fluids levels good….HmmmmDropped idle F/A to 13.8 from 13.5. Slight cold hesitation at throttle tip in noted. It goes back to 13.5 if the IAC adjustment doesn’t take care of it.
IAC a little high. Noted it got to 80% on cold start pull away this morning. Warm IAC is around 15-20%. I’ll adjust that down a bit to warm between 8-12 as per Holley/several videos recommendation.
I’ll drive it a while like this and then pull cruise F/A down (leaner) to 14.2 to start….. Drive. Report.
It’s all related… so one step at a time.
Also finished the model for the 3D print of the pump cover in the trunk….
Cool no? Can’t wait to get the print. Should take about a day to print it.
The blue thing (cut up coolant container) was just to get the profile of the edge for the flange.
This will let me close out one end of this project.
Secret project will have to wait… transmission guy coming in Saturday to check it out. Hopefully it’s an easy fix.
I put a bit of trans medic in (about 8 oz) and it actually made it better. Thinking it was an older rebuild kit and the seals may have been hard or shrunk up a bit. That’s how it feels anyway…
Regardless, i won’t need the NYB next week for actual transportation as the Roadrunner is almost done. Freon R12 delivered, expansion valve… waiting just on the hoses. It should be delivered to my house by Monday.
I didn’t like how the compressor lined up so I moved it a bit to the passenger side to align the belts and avoid/get clearance from the top hose, bypass and heater hose. This required some noggin work to figure out and the addition of a free wheeling pulley to clear the water pump with more than a 1/4 “. Pulley came in today.
Progress today. On almost all fronts.
Also got a new client in the weirdest way I’ve ever gotten one. She’s a pilot for a major carrier and saw one of my public projects on Miami Beach. A bathroom concession building on the beach I did 15 years ago….. go figure! She likes my public crapped and wants me to do her house.
Lol. Life is truly Random!
Same. Although better yesterday.Curious to see what the Trans issue is Jav…had mine rebuilt last year and ever since, it won’t engage right away once places in “D” or “R” until warmed up or accelerated on to build up pressure..fluids levels good….Hmmmm
Keep us posted. Mine only does it on cold start, once warm or Op temp she’s good the rest of the day..Same. Although better yesterday.
Come to a stop in drive, release the brake and it barely crawls forward. Give it a little gas and it engages. Strange.
Worse when cold starts.Keep us posted. Mine only does it on cold start, once warm or Op temp she’s good the rest of the day..
I’ll try that.Only on the first start of the day, especially if the car has sat for several days without being started?
If you start the car, let it idle in neutral for ~15 secs, does the problem go away?
Better but not by much. Had Ivan do it on Monday and report.I’ll try that.
