ya man +1.
I will do some write up here in this post for sure. no offence taken about the brake line job with try #1 , ,, I thought you could just extend the flex hose, I did not know the importance of the bracket, etc.
my old man was a mechanic restoring old jaguars and showing them nationally in the jag owners assoc of America.. he died 20? yrs ago. so I really don't have anyone to ask anymore about car stuff. everything I know is from back then, and everything I don't know I have to wing it. ive never done a drum to disc change before, so this was 100% new to me. and I haven't done a brake job in 20+ yrs either
I went with the ECI kit mostly due to ease. meaning I didn't want to bust out the arms/torsion bars/spindles/ball joints etc (it probably needs it though).
The ECI kit you only have to get TO the spindle. Another reason is that I didn't want old 1973 hardware. its out there to be had if you look, but I didn't want used stuff. especially brakes and wheel components.
It really did bolt on. It wasn't that hard. I did everything with jack, stands, in the driveway. if you are better equipped with air tools / garage / etc it wouldn't be too bad at all. my experience level is pretty low too.
I gave what, $775 shipped for the kit, and $14.99 for the MC at autozone. I spent about $20 in lines and couplings and farting around. $12 bucks for a can and a half of brake fluid. All the part numbers are in this post previously im pretty sure, but the MC is 1 1/32 bore. That was a key thing ralph @ ECI told me. I only found 1 MC with that bore, so I figured that was the one.
It does bolt up to the stock drum booster.
Now to be totally fair, at this exact moment, I haven't been over about 20mph. I took it up the street putting on the brakes about every 10 feet
. . .backed up some and braked, then went forward some more. I got to the driveway to check for leaks,, and had one :/
at the rear pass drum. So I parked it. I hope to get the wheel off tonight and get in there, and fix it tomorrow AM before it gets too hot outside.
At this moment - I had a lot to test. Ive had the whole dash out, trans valve body and seals, new shocks all corners, new wheels / tires, rebushed swaybar, fuel line and filter from pump to carb, new gauges in, etc. so the mere fact that it started, came up to temperature, and no one died is a feat in itself. Then it went thru all the gears cleanly. Then it moved. THEN it stopped!
It is an historic day today over here in the saylor household.
right now, I have no add-on metering valve or proportioning valve. Everything from the spindle up is bone stock. I mean I changed the MC, but the lines and hookups and the stock splitter T and warning combination valve thing under the MC mounted on the frame. to be clear for the reader, the add-on metering and proportioning valves are 2 different things. A proportioning valve is a cut off valve, and a metering valve is a hold off valve. way different things. I was advised to try the brakes first without adding either item, then adjust as needed.
