commando1
I'll pass on yours. Thanks anyway, Zac. I have a set on the shelf. Just seeing if there were some better ones around.
15 ft lbs. is way over tight. Be careful with the oil pump bolts, if you are using a ''high volume'' pump. The bolts will end up to short, and will ''strip'' easily. Leave the ''slinger'' on.
Just a friendly reminder to put the rockers on the shaft correctly so the holes line up for oiling properly. It's in the FSM.
Only bad if it's put on backwards.I left the oil slinger on, Stan. Good/bad?
Thanks Bob! Gotta pick up some new rocker arms first, but ill deff be paying attention!
PM sent......
