Bar across the top puts me at ease compared to the others.Weaver® W-10C Overhead 2 Post Car Lift
Not that anyone asked, I am buying this lift. Direct drive cylinders and 10k lb lift load. Anyone care to pick it apart?
I would go with an epoxy anchor. Way stronger, you have 4-5 inches of adhesion and resistance compared to the quick bolts. We use the expoy at work and you would pull the concrete around the whole anchor out before the anchor itself.My manuel said 4 inches minimum. The base of the post is a good 3/4 to an inch thich. I used the wedge anchors supplied with the lift. I guess they were about 5 inches so about 4 iches in the concrete.
I just drilled a 1/4 test whole. I read some where if you concrete is too thin you can cut out a bigger foot print and pour it thicker. I however never confirmed this with Bendpak, since I had 5 inchesThanks. Yeah, I'd read that 4" is the minimum necessary for a 2-post. I haven't had the courage to drill a test hole yet....
I wish I could have talked to you before I set the posts. I bought a tube of concrete epoxy and chickened out using it because I heard it could set up as fast as 30 seconds. I was more concerned about taking my time and getting the post perfectly straight.I would go with an epoxy anchor. Way stronger, you have 4-5 inches of adhesion and resistance compared to the quick bolts. We use the expoy at work and you would pull the concrete around the whole anchor out before the anchor itself.
So the Engineering Dept. said 6 and the Marketing Dept. said 4....This is from Bendpak's site:
9,000-lb. Capacity / Floorplate / Chain-Over / Narrow
4" Min. Thickness / 3,000 psi
It does say that...Their attorney would probably say... only installed by a company trained professional![]()
Glad no one was hurt. Above ground lifts should have a lock on each arm, I would bet one or more was disabled to allow it to get all the way down... usually they just fold up the bedsides. Dodge dealer I worked for, I had a guy who dropped a Ram about once a month if he needed to or not. They kept him employed to pay off his bodywork tab, I think he had them figured out.
Talent... I'm sure it got hung on something coming down... but thats like clearing a pool table with one shot.I have tried, and tried, and tried, to figure this one out. I can't.
It looks good in their ad... give a real close and critical look at the locking mechanisms... if crap happens, they are what saves you.Weaver® W-10C Overhead 2 Post Car Lift
As to floor thickness... I have always heard 12"(probably for asymmetrical), but never cared enough to check because I was always in shops meant for lifts. PSI of the concrete would matter too, and reinforcement... A halfassed Florida constructed home garage may crack if you park a car on it... I have actually heard of it several times.
So the reason for choosing this lift is that it's "Super Symmetrical".Heavy loads are lifted on equal length arms. Lighter loads are lifted unequally. The manufacturer recommended 4" 2500 psi. I poured 2 18x18x12 deep piers @ 3500 fiber reinforced. I will be lifting 9k lb trucks. The waiting is driving me crazy.
I saw that "super symmetrical" bit... sounds neat, but I haven't ever worked with one quite like it. Zymurgy's open top lift is meant for low ceilings or tall vans... It will most likely be an awesome lift. I like the variety of adapters yours has. Lets be serious... a lift is a super useful tool for working on cars. The detail items are important, but you should be safe working with any of them. IF something isn't right... dont use it until you get it fixed. The locking devices are mostly going to be about when you're not there... and never fully trust anything.
One fire ant bite in the right place... you dont care what it costs anymore...The lift has good reviews.
I'll be the first to say, i'm not a pro when it comes to lifts. I do know, when this lift gets installed, it will be a game changer.
I work on cars all day long. Not having ants and sand up my *** is a welcome scene, almost a fantasy come true.
My brother worked at a Chevy dealer in Denver in the mid-'80s. One of the line mechanics had a '74 Chevy Impala station wagon on a similar lift. It had been up there for about two hours or so; in the meantime, a vendor delivered two 55-gallon barrels of 10W-30 motor oil, and sat them toward the rear of the car while it was elevated. The mechanic did not know the vendor set the barrels there, plus he was at lunch...You guessed it - the car slid off the driver's side pads and fell upside down on the two full oil barrels, which of course, split wide open and 110 gallons of fresh oil got everywhere! The roof of the wagon was severely damaged and the interior was full of oil. The customer had just walked in the service department to check on his car when it happened. IIRC, the service manager got fired, the mechanic got in a shitload of trouble because he did not have the car on the rack correctly, and the vendor employee got fired by his boss for leaving the barrels in the wrong place. The customer got a two-year-old used car from the dealership as a result, as compensation for the loss of his ten-year-old wagon.
I wouldn't feel too bad. I think yours is solid, wish I had it. I would like to check this out someday... but live, the brochure doesn't hold much weight with me. You let it rest on the locks when you store on it... they better be a solid design. I am too tall, the lift would get worked off the locks at max height for me... but they better engage if the hydraulics fail.I took some time and read everything on the site. That thing is a brute. Makes me afraid to even use mine now...
I had/have a set of 4 lifts that used to be set 90 degrees different than they are now. We lost a little storage space, but made a much better flowing shop. Point is the floors aren't level and in their old position they had a side load... we F-ed around with them endlessly adjusting cables and such... once moved to the level location and a manufacturer's recall on plastic sliding blocks they have been rock solid. Now its typical burnt out pumps, switches and occasional seals.The lock refuses to engage automatically on my right post.
I have fiddled with it endlessly. It's simply a poor design.
I have to trip it manually as it goes by an inspection hole on the way up.
There's no need for that BS.
