badvs3vil
Here is the ring set I just bought. I found the STD bore size was 4.342.
More Information for SEALED POWER E318K
What made you decide to paint the oil pan and intake black? Just curious.
I took all mine out of a shiny new ARP box. They sell kits with every bolt required to assemble a BB Mopar.
Other than that I'd put them in ziploc bags labelled by category.
Kevin
You could try Permatex Rust Neutralizer on the smooth cylindrical portion of any long bolts. Permatex number 2 gasket maker or Loctite red thread lock will seal the bolt threads. I’ve had a hard time finding anything that doesn’t break up and fall off the bolt heads during install. You could try painting them black, doing the install, and then covering the bolt heads with clear. On the other hand if it’s black on black, it might be simplest to touch up with black.I only ordered new for the internals. I want to save a couple bucks and reuse the rest. They all cleaned up super nice, just want to make sure they stay that way.
What clear engine paint are you going to try?I got them all cleaned up and shiny steal looking. I think I am just going to clear coat the whole engine after I have it together. Maybe that clear will keep the bolts ok for a while... LOL
Also, did you keep your original pistons?
If not, what did you replace them with?
