Well Doug, I look at my build sheets and the 4 character code says trim code and the TX9 is the UDF code
What is a udf code?
Inner upper door frame paint or color of pad used at the top of the door frame. In earlier years, they were painted. By 71 most had a colored pad of some sort. The color used coordinates with the interior trim color. i.e. Black pad to go with black interior
What is a udf code?
The sheet i found under the back seat is incorrect for the car. Doesn't seem to be one under the front seat. Haven't checked the back seat back yet...Have you pulled the back seat to see what color the floor pans are and to look for broadcast sheets?
Look for sheets in the lower rear seat, the seat back and under the front seat.
Finding a broadcast sheet will answer a lot of questions.
Cop stuff.
Haven't tested it yet lolBut does the cigarette lighter work?
